Nice Engine Layout Pic
Old Jan 31, 2004 | 01:46 PM
Josh's Avatar
Dr. Doom
Originally posted by `92CXhatch
CRIST that is a lot of shit!!! i like my 3 moving parts!!!
-Keith
Old Jan 31, 2004 | 03:38 PM
Half Fast's Avatar
LT1's are slow!
Here's what you need, bring the check book.
Richard
1996 Corvette CE coupe LT1/A4
Mostly stock
1998 Camaro
Z28 badges and dual exhaust tips
Old Jan 31, 2004 | 03:48 PM
0HP930's Avatar
Guest
Originally posted by Leonard
What you buying a book for now??? Has it been so long since you took it apart that you forgot how it goes back together????
Well, I also have the porsche factory manual for the motor but it does not have a lot of the critical specs needed to machine and rebuild an old motor.
For example I will be bumping the compression so I will need information on deck heigth limits that you can't find in any other resource.
Since I am getting my machining work done I need a lot of other measurement specs and would like to know what anerobic sealants are recomended for sealing the different metal to metal surfaces.
I have rebuilt a lot of motorcycle engines using yamabond to seal the cases but those kinds of sealants are not recommended for this motor. Since a couple of critical oil gallies pass between the cases and the last thing a 930 motor needs is a chunk of squished out plasticised sealant breaking off and clogging a critical bearing or squirter. There are lots of different anerobic sealants out there so I would like to know what the top racers and rebuilders are using for their cases and heads before I pick one for my engine.
To answer the other question, the case is held together with long steel bolts that pass all the way through the case and nuts. Its part of the reason for the case's great strength since the fasteners arn't limited by having to screw into the aluminim block.
In fact the 930 block is so strong the same block is still used in the new 996 turbos, GT2s and GT3s.
Old Jan 31, 2004 | 03:54 PM
0HP930's Avatar
Guest
Hey Richard, is there a story behind that pic?
Old Jan 31, 2004 | 06:31 PM
g-50Cab's Avatar
TR Balla Donor Supreme
Hey Tony - did you see this on rennlist?
link
Old Jan 31, 2004 | 06:35 PM
Half Fast's Avatar
LT1's are slow!
It was in the garage area at Daytona on Friday.
Old Feb 1, 2004 | 09:02 AM
  #17 (permalink)
0HP930's Avatar
Guest
No, in fact I don't even read the rennlist anymore since I found the pelican forums.
That fact aside, I can think of a lot better places to spend my money than whittling down the crank.
I can see the sense in it for some motor being set up to regularily spin over at 8K RPMs but my motor will rarely ever see even 7K.
If I wanted to lighten up the rotating mass I could easily start with the clutch. That damn 930 pressure plate weighs over 20 lbs. I have concidered going to an aftermarket aluminum unit when the current clutch wears out.
