DC Sports upper front strut ....
I have kind of a funny prob.... i have a dc sports upper front strut on my accord... and it squeaks...or kinda creaks around where it's bolted together. Could it be that it needs to be retightened? Anyone ever have a prob with this ?
it probably just needs to be tightened, i've had a nuespeed one on my car for about 6 years and never had a problem.
TR happily married crew-member #2
___________________
___________________
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Re: DC Sports upper front strut ....
2012 FIAT 500 ABARTH
Re: Re: DC Sports upper front strut ....
Originally posted by Tom
then check it? ....just doushe it with wd40 or somthing hahaha
WD40 is a solvent and will break down chassis grease. It will eliminate squeaking temporarily but it will probably come back again later and be worse.
Keep it away from ball joints, grease fitings, tie rod ends, control arm bushings, etc etc.
Vehicle Repair/Maintenance and TIG welding services for hire (steel and Aluminium), PM or IM me
AIM: Acidtalons
AIM: Acidtalons
its just squeaky bushings...mu camber kits do that too. it will happen until they are properly worn in or"seated"
helping bring peace to the world, 1 party at a time
Saggleman: cause lord knows theres nothing i love more than swallowing condoms full of cocaine
Re: Re: Re: DC Sports upper front strut ....
Originally posted by Acidtalons
WD40 + suspension = bad.
-93 MR2, #129 ES
-93 MR2, #129 ES
Re: Re: Re: Re: DC Sports upper front strut ....
Originally posted by PseudoRealityX
WD40 is a water displacer, not a solvent.
Also WD40 says right on the can:
"Cleans, Displaces Moisture, Penetrates, Lubricates and Protects."
AIM: Acidtalons
AIM: Acidtalons
Yeah that stuff definately works well as a cleaner/solvent. Used it many times to remove sticker boogers off various surfaces. Works very similar to gasoline for removing adhesives.
