squealing
Old Dec 9, 2003 | 03:34 AM
fresh&clean's Avatar
I love Lamp
Default squealing
Ok since the cold weather has struck my car squeals right when I start it up its really bad I almost went deaf it used to do back when it got cold and I never found out why does anyone have suggestions.
Old Dec 9, 2003 | 04:05 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
This is only a guess, but i would say it's because your belts are cold therefore more contracted and tight, i would think that would cause the initial squeal. Like i said this is only a guess.
Old Dec 9, 2003 | 12:56 PM
I love Lamp
Thanks
Old Dec 9, 2003 | 01:44 PM
Illswyn's Avatar
Would they really contract that much? It's not really cold out.
Might want to change the belts anyhow, just in case. My wagon had a squeaking belt, determined it was the alternator belt, bought all new belts. 2 days later, it stopped squeaking, because the belt broke! Fortunately I had the belts in the car, so I just changed it when I got where I was going.
Dunno...could be your PS pump needing fluid, mine squeals when it has drained (I have a leak). Fillerup and it stops squeaking.
Old Dec 9, 2003 | 03:11 PM
KrazyInKamo's Avatar
TraumaInDHead
belts need to be oiled.. they have stuff at autozone in a spray can for that...
You Are All Gunna Die...
Old Dec 9, 2003 | 03:12 PM
TraumaInDHead
well..not neccessarily oiled but if it's really dry the rubber doesn't exactly have elasticity...
Old Dec 9, 2003 | 07:20 PM
I love Lamp
Well also when I downshift its squeaks a little too but only when the car is cold also when I downshift to go faster not for stopping.
Old Dec 9, 2003 | 07:59 PM
0HP930's Avatar
Guest
You could also have a bad idler pulley bearing.
Old Dec 9, 2003 | 08:54 PM
Nah it's your rotator splint.
