squealing
Well sometimes my car idles at 1100 rpms and sometimes at 1000 and other times at 900 I dont know what is wrong but I think Im just gonna sell it!
could be your muffler bearings.
TR happily married crew-member #2
___________________
___________________
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
I'm thinking doofalator valve. In all seriousness though, it probably is just your belt slipping until it heats up (kinda like tires) It doesn't really contract, it's just not as soft and therefore looses grip. Get a new belt. I also had a Nissan pickup that would make a howling noise for a second or two, and then the first couple of times I shifted until it warmed up. It was the throwout bearing, and it wasn't bad, it just howled on cold mornings, did it for years.
easy fix..... check belts and tension in the belts too much or to little can cause this more than likely its your fan belt..... DO NOT RUN HARD THROUGH THE SQEAL U WILL BREAK THE BELT! ive done it it leaves u stranded it sux
collision and refinising technician need bodywork/ paint call 727 776 7830
