what exactly makes a motor sound like it does??
Old Nov 16, 2003 | 03:44 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Originally posted by `92CXhatch
it was a joke there cock boy... i know what my motor consist of... i just didnt think that i needed to get technical over a joke... but i will try harder just for you man!!!
-Keith
Look asswipe it's not my fault you got a fucking goofy engine and you don't know what's in it!
Old Nov 16, 2003 | 04:17 PM
Whaazup17's Avatar
Originally posted by Mars_302
Firing order, if its an inline, a 90 or 60 degree motor, amount of cylinders is what really defines it.
what makes an engine break up? Like you hear a late model mustang and it is all one sound but you hear the dragsters and you hear it unconsistent?? What makes that? you hear each individual firing order..... I dont understand that?
Old Nov 16, 2003 | 04:34 PM
Strokd85's Avatar
Daddy-O
cam shaft profile, head/combustion chamber type, compression, idle, etc...
it all plays into it..
also, if you're talking about the T/F dragsters, they're in a class all to their own with the Nitro Methane they burn...
I am your penalty.....
Old Nov 16, 2003 | 06:47 PM
  #18 (permalink)
g-50Cab's Avatar
They are all basically airpumps. Some are just better than others.
my favorite is the Ferrari flat 12 - and the V-6 in the Dino, and of course the Porsche Flat 6 at 6800 rpm's!
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
Old Nov 17, 2003 | 08:02 PM
  #19 (permalink)
Vicious's Avatar
Mobile Agile Hostile!!
Default Re: Re: what exactly makes a motor sound like it does??
Originally posted by LS_ken-e
HAHAHA! gotcha....
well, i know with hondas it depends on what you're feeding your hamsters
thats funny as hell
Old Nov 17, 2003 | 11:51 PM
  #20 (permalink)
722ish's Avatar
ASM FTW!
Originally posted by PoppaSmurf
heres one....a mitsubishi 4G63, between the first and 2nd generation motors, the heads, compression, and intake manifolds are substantially different, yet they still sound VERY similar...im just trying to figure out why, figure it might make for a good tech discussion too
that and EVERY subaru sounds the damn same... the dohc 16v 2.0 ej20 open deck, the dohc 16v 2.5 semi closed deck ej25 in the STi, the SOHC ej18 1.8L, the SOHC 2.5l ej25 n/a...
for some reason they all sound the same, or very similar, even under boost with a header like mine, as the stock manifolds are as far from equal length as it gets!
95 Supra Turbo 6 speed
11 SWP STI sedan
