found my wheels *drool*
TR Balla Donor Supreme
on
pretty much .. i am hoping thet have them in a wider pattern than mine (17x8 doesnt cut it) .. hoping for 17x9 and 17x10.5 .. but we'll see..
I've been searching for something deeper.. with a wider stance with the dark bits in center like that and a silver lip for a while..
Stuff.
Stuff.
I like those way better than the factory ones
Originally posted by Road Rage
i would get those in the back and leave the stock ones in the front.
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Originally posted by Billy
Does the side exhaust still have to run past the axle and make a U-turn to get out the sides?
200 points away from a 300
