What shocks do you use?
If you want all aroung then go with Lakewood 70/30s up front and 50/50s in the back.That combo will drive close to stock and give you better traction at the track.Or go with Drag adj. ones then you can have the best of both worlds.........
Guest
Posts: n/a
I have the Griggs coilover's in the rear which are Koni's but made especially for Griggs. Not sure what the valving setup is as they keep it secret but it seems to be a well rounded combination (kind of wish I had them all the way around). I'm using 175lb. c/o springs in the rear.
As for the front they are a 70/30 (another custom job from AJE) with 200lb. c/o springs. A little soft for "good" handling but work well and have good lift capabilites for the launch.
