Help,help how to get lifters out 302
iam workin on my mustang 302 i wonted to know how do i get all the lifters out,do i have to take the valve covers off and take that stuff off,i mostly work on honda so this stuffs kinda new to me
plese help
plese help
I've removed plenty of lifters without having to pull the heads. You should have no problem. Just yank the intake and valve covers like everyone else said. Again, why do you need to change the lifters?
If there is that much stuff up in the lifter valley, I would hate to see what is down in the oil pan as well as the throughout the rest of the block. The best thing to do would be to take the engine out, disassemble it, and hot tank the block. If this isn't an option, make sure you change the oil after you clean the lifter valley. Some of that stuff is bound to fall down the oil return holes, not to mention any anti-freeze that probably found it's way down to the oil pan when you took the lower intake off.
Guest
Posts: n/a
if its that bad id pull the pan and clean it out, clean the lifter valley the best you can, put some fresh oil in it run it, and drain it, and then fill it again with some oil and engine flush.. But I wouldnt do the engine flush till you have a lot of it. You dont want too stop up the oil pump pick up
