Does anyone get Ignition ping from 87 octane?
Old Feb 6, 2003 | 05:22 AM
Levi's Avatar
Default Does anyone get Ignition ping from 87 octane?
I was running 87 octane and getting pings under load, pressing down the gas...87 is what Ford says to run on the 4.6 01 GT...
I already know 87 burns faster and hotter, is 93 a waste of time....
custom parts is our perfection.
Old Feb 6, 2003 | 06:18 AM
98MODMTR's Avatar
TR Balla Donor Supreme
<---runs 93 and higher only
"The problem with socialism is that you eventually run out of other peoples' money." Margaret Thatcher
Old Feb 6, 2003 | 06:20 AM
98MODMTR's Avatar
I had 3 bad experiences running 87...who knows if my car truly needs a higher oct fuel...but if my car could run on 87 like it runs on 93+, i sure as hell would put it in....anything to save money....
Old Feb 6, 2003 | 06:31 AM
0HP930's Avatar
Guest
If it recommends 87 and its pinging under load I would just recommend bumping up a notch to 89 to see if that does it for you.
Does your car have a knock sensor? If it does and its not correcting this issue before you can hear it then perhaps it is kaput.
Old Feb 6, 2003 | 08:28 AM
Toma's Avatar
Ricer In Training
Default Re: Does anyone get Ignition ping from 87 octane?
I would run 93 in a heartbeat if I heard pinging.
You gotta run higher octane even if just have intake or/and exhaust done.
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Old Feb 6, 2003 | 08:55 AM
Levi's Avatar
Why then does Ford say to run 87? The compression ratio is not really high enough to run 93.
The ratio is 9:5
I am thinking I have another problem?
Old Feb 6, 2003 | 09:46 AM
Hondahunter97GT's Avatar
Red Stripe Beer!
ya i have pinging noises when i run 87 so i run 93 always
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
Old Feb 6, 2003 | 10:34 AM
Levi's Avatar
Is it even possible to change the timing on a newer 4.6 engine?
Where can I find data about the knock sensor, O2 sensor, and setting the timing for the 4.6?
Thank you very much guys....
One more question. Would the MAC CAI make it ping, becuase its running lean from too much air? I always thought the air meter would handle that?
Old Feb 6, 2003 | 12:44 PM
tbroush's Avatar
99+GTs don't have knock sensors only cobras do and you can buy a Timing adjuster from Steeda if you want, but like everyone said just run 89 or 93 and see what happens.
Carlos
