Does anyone get Ignition ping from 87 octane?
Before the mods, I got some pinging on hot day's, bumped up to 89 and it cleared it. Now I run 93 due to mods such as timing adjuster at 14 deg, and C&L maf. I was able to sucessfully run 89 octane last week on a road trip to Missouri, turned the timing down to factory spects and only had slight pinging under hard acceleration. i found if I did not rev it past 3500, no ping.
Member Modern Mustangs of North America
http://www.modernmustangs-na.com
Originally posted by Levi
Why then does Ford say to run 87? The compression ratio is not really high enough to run 93.
The ratio is 9:5
I am thinking I have another problem?
The ratio is 9:5
sound good to u?
run 93 and start bitching bout gas prices, its worth it!
Mine was pingin then it stopped after I started 93.
My friend said its cause ure timing is off, nahh its the gas all the gas
uhhum, who told u to run 93 , chris??
CombatFitnessBlog.com
Click ^^ to receive the controversial Ebook "Maximize Your PT" for FREE
People fear what they don't understand, hate what they can't conquer. Guess it's just the fury of man!
Who are the Hardcore lifters?? StrengthCamp RyanMagin.com
sad part is i knew a friend that did all the gas delivery and it was all the same gas for all the 83 89 93or w/e other numbers there are the only thing that makes it higher is this solution that he put in after he fills the tanks and btw the solution he puts in is only like a teaspoon.but i might be wrong
PS i have a pinging noise and i dont think its my gas
There is one tank of high test and low test at every gas station. The pumps mix the two to give you the 3 or 4 different octane fuels.
hahaa u bastard....
but , its working .
1.90 a gallon at mobil station, gotta love that shit!
I hope we nuke saddahm and then steal all of the fields so gas becomes like 99 cent a gal....
