Best Manual Trans For Drag Racing ?
Old Feb 4, 2003 | 05:49 PM
Alan's Avatar
drives euro trash
Based on pure power handling capability, I would lean towards the T-56. It seems you can build those things strong enough to take whatever you throw at it.
Old Feb 4, 2003 | 05:56 PM
craig_302's Avatar
boostmonkey
Not the 3550. If you are dead set on a 5 speed also give the TKO a shot. You can order it with shorter gears as well.
If money was no object, T-56 all the way.
Old Feb 4, 2003 | 06:37 PM
Trouble's Avatar
No Soup For You
Ford Racing Six speed??? I think its M-7003-H you should be able to look that up with ease I believe I read its rated @ 440lbs/ft. torque
I personally like the D&D Performance Viper T-56. Rated @ 550lbs/ft. torque
2.66 1st
1.78 2nd
1.30 3rd
1.1 4th
.74 5th
.50 6th
What do you like Scott??
Twin Turbo '88 Mustang GT
Old Feb 4, 2003 | 07:48 PM
Strokd85's Avatar
Daddy-O
G-Force..without a doubt! only if I had won the lotto, i'd have one right now...
Tremec's are solid, Mike (yellow 95gt) is putting about 500rwhp to one (don't know the torque), no issues.
Old Feb 4, 2003 | 08:04 PM
StreetDriven's Avatar
I <3 your mom
Originally posted by "Mars_302"
id take a t56 thank you
thats what i had it worked great
Old Feb 4, 2003 | 08:36 PM
bitemark46's Avatar
Got traction?
T56 is not a tranny for drag racing. U want a tranny with a big first gear ratio. Scott if I were u I would get the TKO. It has a bigger input shaft and also I think tailshaft. They take a beating. First gear ratio of the TKO is 3.27 and with a 5th gear of .68 which isn't bad for cruising. With the TKO u have to change your clutch disk. -Mark
98' cobra
Old Feb 4, 2003 | 09:06 PM
stangerang's Avatar
whoopdy fucking do!
what about the richmonds???? i dunno about them but they seem reasonably priced......
i have read only good things about the TKO... in fact i have never seen heard or read andything bad about the TKO ... they are supposedly bullet proof......
200 points away from a 300
