stall
It won't be a very friendly street converter, but you can make it work.. Trans might run a little hotter, so I'd definately have a cooler installed. For a street converter I'd have something in the mid 2k rpm range..
Of course, you'll never get it to stall that high without a trans brake, foot braking it will get you to about 2000-2200rpms..
How does a tranny brake specifically work? Can you post up a pic/ or what components does it consist of/ how does it interact with tranny? I've talked to people that had them, but their cars were built in a pro shop, so they didn't know anything about them
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Originally posted by "racingtheburg"
is a 3800 stall with a 411 8inch ok for street use?
Not if you're gonna drive it around town a lot, or it's your daily driver.
In a nutshell what a Transbrake does is lock first and reverse through a solenoid when the button is pressed. Once the button is released the reverse gear is released and the car launches forward (like popping the clutch in a stick car). With having your gas pedal pressed all the way to the floor, the RPM that the motor revs up to while on the brake is called the "stall".
Here's a good link that talks about how the transbrake's internals works.
Also, you will need to have a reverse manual valve body to use a transbrake. There used to be someone who manufactured a standard valve body with a brake, but I have not seen it for some time.
http://www.fbperformance.com/techtips/transbrake.html
Haha, figure witht hat you may have about 1000 rpm of useable power, should be even more of a turd..lmao
10' 1198S
09' Ninja 500R
09' Stella
10' 1198S
09' Ninja 500R
09' Stella
