Rear wheel question 89 GT
correct! Same as it would on a 10" wheel.....1" wider from hub face out...and 1" inboard. (comparing to an 8" w/5.5bs). Its hard to type out...I think you'll pick up what I'm saying (hope) lol
The problem is the 5.5 BS using a 275/60 is already tight on the fender lip. So any movement outward would be an issue.
The 15x8 and 15x9 having the same back spacing means the 15x9 is 1 more inch outward. Now the 15x9 and a 6.5 BS would be one more inch inward and same BS on the face. Technically a 15x9 and a 6.0 BS would be ideal. That would be =.5 and -.5 and keep the tire in the same place with more meat.
I can always move a wheel outward using a shim or spacer. The opposite direction... good luck. And once you mount a tire on a wheel.. you bought the farm
Hell the fix is minitub the car so I can make the wheels fit. Thats the Moby Dick fix... come hell or high water.. i'm gonna get that whale(make it fit)
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
A 15X10 w/ a 6.5 back space is what ya need. If the rim sticks out too far because of the disc brakes, just shorten the housing a half inch or so to pull the rims back in. No need to mini tub the car. A 15X10 inch rim w/ a 6.5 back space with a 28X10.5 M/T slick will fit as long as you roll the outer lip and get busy with a hammer on the inner fenderwell. Most of the 275 series tires out there measure just a little shorter than the slicks and don't seem to grow as much either.
ON3GO
For Sale/WTB Nissan
Aug 31, 2008 12:09 PM
