a4 block
Old Dec 1, 2002 | 10:14 AM
  #21 (permalink)
race495's Avatar
Pull Over
Originally posted by "Strokd85"
you wouldn't want to run it on the street either, fewer water passages, etc.
but it'll take some serious beating on ...
also, add about another 500-700 in prep and finishing work...
as Jomar said my R302 has absolutely no overheating issues with a 3 core brass/copper radiator, police clutch fan and a supercharger to add heat. can drive it to california tomorrow if I so desired. the cooling issues of R302 blocks are a myth. best way to put it is that a chevy 400 smallblock is also a siamesed bore motor and they came in many production vehicles without issues. it is when you do not correctly set up the coolant passages on an R302 block that you get into trouble.
also there are people who have trouble with anything and everything they build.
My setup is not an exception either, I researched this cooling myth for a good while and found a lot of daily driven 500-600 rwhp R302 cars around the country with no issues except traction
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
