rear end question
Old Oct 18, 2011 | 12:51 PM
50Mustang's Avatar
Default rear end question
i am taking my fox to 5 lug from 4 lug i have t he rear axels, when i pul out the 4 lug axels, what seals or bearing do i need to replace? i know there has to be some that need to be replaced im just not sure what ones or their names any help would be great thanks.
Old Oct 18, 2011 | 05:32 PM
blacksheep-1's Avatar
Actually none, axles out, new axles in. Inspect the old axles around the bearing area, normally what happens is the axle is the inner bearing race (like a GM 12 bolt) this surface will wear, it will be apparent in pitting and a worn surface. That will be the key to replacing the axle bearings. You can remove them from the outside of the axle by using an "L: shaped pry bar and a hammer, I'm sure there is some trick tool to do this, but you can crude your way through it with relative impunity and not hurt anything. The new bearings are pounded into the tube along with the new seals, put some aviation permatex around the seal to seal it to the tube. I found a brass drift, or metal tube to "press" the bearing into the tube, just don't beat on the bearing itself, but on the outer race. (recover ALL loose bearings!)
That's really about it, the carrier bearings usually last forever unless the rear has been run dry, you might want to replace the pinion seal, that's about it. No huge deal.
Old Oct 18, 2011 | 05:47 PM
50Mustang's Avatar
cool man thanks for the info
Old Oct 19, 2011 | 10:33 AM
50Mustang's Avatar
what kinda differential fluid should i use? is one better than the other?
Old Oct 19, 2011 | 01:48 PM
I use a synthetic that is Ford spec, you can usually get it at Advanced, NAPA, etc.
Old Oct 21, 2011 | 09:40 PM
Brutal Metal's Avatar
I like Amsoil with a 4oz bottle Ford friction modifier
SVT Cobra-Teksid.020(284ci)
Stock HCI/Forged Crank
Manley Pistons & H Beam Rods
Polished Vortech V-2,GodSpeed SpecV Intercooler
MPH Powerpipe,60's,Twin Aviator's,Kenne Bell BAP
Reichard 3.1,SCT BA-5000,ProCharger Pro-Flow BPV
Auto Meter Z-Series Gauges,Mac O/R H & 2.5 DuraBlack CB
Vogtland 1.6, MM CC Plates,Steeda Tri-Ax,Billetflow IRS Brace
Vortech Intercooler Fabrication Joe Bonczek/Custom Piping
SCT Tune Rob Wells@ Ford Speed Racing
wishiwasfast
Oct 11, 2009 09:11 AM
rangcrx
Nov 7, 2007 02:00 PM
DouglasProbe
Toyota/Lexus Tech
Jul 11, 2007 06:45 PM
98svtcobra
Jan 19, 2007 03:17 AM
blown1989stang
Apr 14, 2006 12:54 AM
