Ticking noise after upper intake replacement
Old Jul 9, 2011 | 04:09 PM
Bumpin Expo's Avatar
Reppin' the 813
Default Ticking noise after upper intake replacement
Hey guys,
2001 Ford Mustang GT. Had to change the upper intake due to the thermostat housing. I guess the original owner never got the recall done that required the intake to be replaced so the plastic thermostat housing gets replaced with aluminum. Anyway, now I have this problem. I have a ticking noise and I feel like it has lost power. Any ideas?
http://www.youtube.com/watch?v=Emfk5GzLzUM
Old Jul 9, 2011 | 05:03 PM
st pete chad's Avatar
vacuum leak ? buy a can of starter fluid and spray it around where the intake seals if its a leak the car should rev up or stall thats how i have always checked for leaks
[IMG][/IMG]
357w s475 turbo Hughes powerglide
Old Jul 9, 2011 | 05:59 PM
Reppin' the 813
Thanks for the reply. I see you drive a stang. Are you familiar with the PI swap on the stangs?
A vacuum leak would cause the noise in my video?
Old Jul 10, 2011 | 06:26 PM
i had a 99gt and had to replace the intake for the same reason.i know on mine i had a leak and it kinda soundedlike yours does thats why i said just try some starter fluid and see what happens
[IMG][/IMG]
Old Jul 11, 2011 | 03:01 PM
$hawn's Avatar
lives in a glass house
exhaust leak from the egr tube??
Old Jul 12, 2011 | 04:27 PM
EsCoRtLvR's Avatar
Escort Connoisseur
Sounds like an intake manifold leak. Looks like you have the updated manifold on the car though (the one with the aluminum coolant passage). I would look at the fuel trims and that will tell you right away without spraying flammable fluids all over your engine bay. If you must spray stuff on your engine use water in a squirt bottle. Just my .02
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
170k240
Nissan/Infiniti Tech
6
Dec 17, 2005 08:15 AM
blog
Nov 24, 2005 05:00 PM
88crxb16
Jun 23, 2005 06:29 PM
Cairey
31
Oct 3, 2002 07:47 PM
