OK.. so since I have never "experienced" this befo
Old Oct 23, 2002 | 01:23 PM
Faethor's Avatar
WIP
Default OK.. so since I have never "experienced" this befo
could someone explain "clutch chatter" to me?
Is it more feel than sound? I just had the Spec clutch and Steeda cable/quadrant installed and I am feeling a small shudder in the clutch pedal as I depress it... is that what this is?
The Iron(FE)-Works
My daddy always said, "When you want to hammer a nail, don't do anything fancy. Just get a hammer and pound the son of a bitch."
Old Oct 23, 2002 | 03:45 PM
Faethor's Avatar
WIP
Next "stupid" question then...
I'm going to try and get it back to David before Sunday.. if I can't should I call Track Day off?
The Iron(FE)-Works
Old Oct 23, 2002 | 04:03 PM
Road Rage's Avatar
Shake n' Bake
when did you have a clutch put in and how many miles are on it?
Old Oct 23, 2002 | 04:51 PM
Faethor's Avatar
WIP
Had both put in this past weekend and it probably has about 100 miles on it so far.
The Iron(FE)-Works
Old Oct 23, 2002 | 04:52 PM
Faethor's Avatar
WIP
[quote="mustang23"]I wouldn't worry too much. Drive it next week, it MAY work itself out. Sometimes the cable doesn't get lubricated all the way and it may stick too. It won't hurt anything to drive it or race it (unless for some reason the clutch sticks and doesn't disengage all the way, causing the clutch to slip non-stop). Just drive it, if it gets worse, or if you smell clutch or it drives funny, park it, otherwise.......
[/quot]
The weird thing about it is that it is not consistent...
I was thinking that it was nothing to be worried about (yet).. just wanted another opinion
The Iron(FE)-Works
Old Oct 23, 2002 | 08:42 PM
Road Rage's Avatar
Shake n' Bake
i wouldnt worry then, it i supposed to do that sometimes on some cars it even says so in the instructions, i believe break in period is between 500-1000 miles not sure though.
Old Oct 24, 2002 | 04:37 AM
Faethor's Avatar
WIP
Thankee sir... I figured out this morning how to explain the feeling when I press on the pedal... ya know that squeeky feeling when you rub your finger on something really clean (no.. don't go there ).. it feels like that squeek.
The Iron(FE)-Works
Old Oct 24, 2002 | 08:42 AM
Road Rage's Avatar
Shake n' Bake
did you get a new flywheel or have it resurfaced.
