gearing vs torque
alright guys, i have a serious question that i've asked several people and nobody can give me a straight answer.
my question is this...does the gearing affect torque on a dyno?
what i mean by this is, i just put a transmission in my car with 4.785 final drive vs 4.40 final drive. obviously my car accelerates better and pulls harder through the gears because the motor has a better advantage.
now it seems like this would also increase the overall torque output of my car. i liken torque to twisting power, hypothetically speaking, if you could put a car on jackstands and hold the wheels from turning, the car with the shorter final drive would be able to twist and turn better which is torque, isn't it?
anyway, just wanted to see what you guys had to say, as i know a lot of you have installed 410 gears into your mustangs and have probably put your car ona dyno before and after this...
if anyone could explain this to me, i'd appreciate it...and if i'm wrong, please correct me.
thanks, chet.
thanks, chet.
Guest
Posts: n/a
Dynojet says that gearing affects HP on their dyno. I say if it does, their program is flawed. Before starting the dyno pull, you hook up a tach signal to the computer. The computer then calculates the rate of change between the motor accelerating, and the dyno accelerating. That is why there should be no difference in the HP shown based on gearing.
so in essence, lower gearing just affects acceleration...which we all know is true...
see i would agree with this completely, but the example i was using before with holding the wheel seems to support an increase in torque.
Guest
Posts: n/a
I still think it shouldn't affect power. Remember, the dyno is ONLY measuring torque and figures out HP from that. Since it sees how fast the motor is moving compared to how fast the rollers are moving, then it automatically knows what gear ratio you have in the car and thus should be able to calculate accordingly. We tried to dyno my friends El Camino, and it kept stopping the run because it was all screwed up by his stall converter (motor revved real high then wheels started to catch up).
alright, does this sound correct also: the car doesn't make more torque, its just able to make better use of the torque it already has?
like a 200lb person sitting on a seesaw, the further out the person sits, the more mechanical advantage, or leverage, but the weight remains the same.
this would mean then that the stress on the driveline is increased with longer final drive...and acceleration would also decrease.
Guest
Posts: n/a
there is a torque multiplier at the wheels depending on the rear gear ratio. doesn't change the torque value the car is making but to give you a idea we use a calc. to figure what size axles you need to support your HP level. Take a look at this link. http://www.moserengineering.com/moser_interior/axletech.htm
Hehe...your all wrong. During acceleration it will decrease HP and TQ slightly measured at the wheels with a dynojet depending on the drop in ratio. Fbody guys have disussed this for years since the drop was significant due to wide gearing changes. They would always see from 5-7 rwhp and Tq loss accross the board when going from stock 3.42s to 4.10s. The reason is due to the more rapid rate of engine spin up. It takes less time to spin up all the rotating mass in the driveline and engine so therefore more energy is being consumed to acclerate the engines own rotating mass and not transmitted to the wheels though gearing. I have to do a search but I wrote a lil something about this a while back. It was archived on an Fbody tech page. Its a lenghty explanation so im going to find it and copy and paste it here.
*edit*
damn...wouldnt let me copy of the website. So heres a link. Disregard the reply under mine half way down the page...the guy didnt quite get what I was attempting to explain.
http://www.ls1info.com/article.php?sid=167
*edit*
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
