Need help please.
Old Mar 9, 2011 | 05:00 PM
GNs-r-slow's Avatar
Bondsman
Try the wrench and hammer method, the arent usually that taught
Old Mar 9, 2011 | 06:28 PM
harold harper's Avatar
h9
you could make a tool to fit in those two holes,basically a spanner wrench or take three pairs of vise grips to the pulley a wedge them in place to hold so you can turn the nut.
Old Mar 9, 2011 | 06:31 PM
$hawn's Avatar
lives in a glass house
air chisel with the point tip...point it toward the correct side, one quick hit, spins the nut right off.
Old Mar 9, 2011 | 06:32 PM
95coBraSVT's Avatar
banana republic
Hurst, No offense was meant. I promise.
Onward....Try to see if you can remove the fan clutch assembly first. Then, if that doesn't work, try to put a stubby screwdriver into the holes and jambing the pully a bit on the pump housing with the screwdriver poking through.
Piss poor design? From Chevrolet? Say it aint so! LOL
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Mar 9, 2011 | 08:09 PM
herrcomestrouble's Avatar
This!.....
I have a master kit, with all different size wrench ends, with "hooks" for the air hammer head to grab onto.... If you need something to borrow. Let me know.
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Mar 10, 2011 | 03:55 AM
Hurstmeister's Avatar
I tried that yesterday. The first one I made from an old bracket and the metal was too thin and just bent as I tried to use it. There went 1 hour shot. I have some angle iron here from a trailer repair I did. So at first I cut up a bolt and welded the ends to the angle iron to fit in the holes. But the ends kept sheering off and wouldnt hold. So I drilled holes and put bolts through where I could bolt the tool to the pulley and all I did was break bolts left and right. 3 hours shot in that process. Basically wasted my day trying to make something work,.. and all I did was make myself frustrated and pissed off at GM for making a retarded design like this.
Wake up early this morning thinking I'll run out to Sears and get a strap wrench and its a friggen torrential down pour with thunder and lightning out. The 6.0 is safe under the roof on my back porch. But no way in hell I'm doing the water pump in my truck in freezing rain plus I dont mess around when its lightning out. I had a bad experience when I was younger and saw first hand what a man looks like after getting hit with lightning. I threw up and have had nothing but respect for it ever since.
I'll keep you guys posted. The rain is supposed to let up later today. I'll take a crack at it then. I want to experiment on the 6.0 first before I do the 5.3 in my truck. Sometimes what seems like such a simple job turns into a cluster fuck like this when you dont have the right tools. Besides the 5.3 in my truck which other than knock sensors and regular maintenance has been trouble free for almost 4 years now. I'm approaching 120k on my truck. Going back on memory,.. previous GM water pumps on older older motors were usually good for about 50k miles. So I guess getting 120k out of this one is doing good. But then I had over 200k on the factory water pump in my 2v 4.6. This is my first time really working on the GM LSx engines. Really have no experience before this. I have to admit though,.. the learning curve here is much simpler than when I first cracked open the 2v 4.6 in my 96 Mustang.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Mar 12, 2011 | 06:30 AM
  #17 (permalink)
Good news and bad news,.. well not really so bad,.. but sucky just the same.
Replaced the water pump in my truck,.. no problems. Finshed it start to finish in about 1 1/2 hours. One of the easiest I've ever done. For shits and giggles I put the wrench on the bolt, whacked it with a hammer and viola. It broke loose. No fighting, easy peasy.
I bought a chain wrench for the 6.0. Locked the water pump pulley. Put the wrench on the nut,.. beat the piss out of it with the hammer and nothing. Would not break loose. I pulled the water pump off and took it and the clutch fan assembly still attached to it over to my inlaws place. I hit it with an air chisel and did nothing but put gouge after gouge all over the nut. I put the pump in a vice and put a 36" crescent wrench to the nut,.. I beat on it with a 10 lb sledge hammer and did nothing but strip the nut.
So I've called quits. After buying the water pump for my truck I see that they come with a new pulley and new copper gaskets. I will just buy a new water pump for the 6.0 and call it a day. I was so worried that I wouldnt be able to get the nut off the 5.3 in my truck,.. turned out that 6.0 pump was DOA before I ever tried to break it loose. Oh well,.. win some lose some.
Thanks for the help guys.
Hurst
