re-gearing?
Old Feb 23, 2011 | 05:41 PM
88_Hatchy's Avatar
I'm cooler than you
Default re-gearing?
What are you guys paying to have your 8.8 rear ends rebuilt?
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Feb 27, 2011 | 09:58 AM
blacksheep-1's Avatar
If you are careful and you use Ford gears, and of course, have some decent tools like floor jacks and impacts. You can actually do it your self. Now I'm sure someone's going to jump on here about that being impossible but whatever, if I could build a 9 inch in my back yard at 17 years old, for my 57 Chevy, anyone can do it. The key is to use Ford gears, it takes a bunch of the guesswork out of it.
Old Feb 27, 2011 | 01:17 PM
Tiffiny's Avatar
I can fix your bullshit
dont forget the 0.30 pinion shim.........
Old Feb 27, 2011 | 04:31 PM
You mean this one.....
Pinion gear mock-up:
Remove the bearing from the old pinion using a press and bearing separator, as illustrated above. Remove the shim from the pinion; measure and record the thickness. The nominal shim thickness used on an FMS gearset is .030", but can vary +/- .002". If you are installing FMS gears, look closely at the new pinion; it may be marked with a +2, +1, 0, -1, -2. If so, that "number" is added to .030" (e.g +2 would indicate the use of a .032" thick shim; likewise, the -2 would require .028") to obtain the proper shim thickness for that gearset. Regardless of the marking on pinion (which is an expeditious method of getting close to correct pinion depth), the final result should always be checked with proper tooling and marking compound.
http://www.corral.net/tech/drivetrain/gears.html
jlude90
Apr 29, 2008 04:33 PM
Teggy02
Jun 4, 2007 05:35 AM
fresh
Aug 24, 2006 10:59 AM
xTegzy
Feb 19, 2004 07:02 PM
MattC
Jan 9, 2004 12:37 PM
