loud clunk...wtf is it???
Old Sep 13, 2002 | 03:58 PM
superdave's Avatar
Default loud clunk...wtf is it???
Problem:
put car in reverse, give it some gas, pull the clutch and CLUNK...feels like the transmission just abruptly moved to the left.
put it in first, give it some gas, pull the clutch and CLUNK...feels like it just went back to where it is supposed to be.
It doesnt happen if i baby it forward and backward, only if i hit it a little hard. from the drivers seat, it sounds like its right below me. feels kinda like something coming out of joint and then going back in. driveshaft? trans mount? inside the t45?
Old Sep 13, 2002 | 04:48 PM
5SlowRacer's Avatar
~ST0N3D~
I'm havin the same problem but it sounds to me like the u-joints are going bad... other then that I would say its possible the tranny mounts are shot.
85' Mustang GT 5.0 $1500 obo!!!
03 FOCUS ZX3
NICK
Old Sep 13, 2002 | 05:28 PM
superdave's Avatar
Default Re: loud clunk...wtf is it???
Originally posted by "FordMan"
I would say trans mount if you have no grinding sound. Does it drive o.k. once you slowly let the clutch out and go ?
it seems to drive fine. no real vibration. if i do it in reverse and then baby it in first it doesnt make the noise. i drove through the parking lot of my office and after a lap i hit the gas hard and it clunked back.
if it's the tranny mount, should i go with a poly or solid one (my motor mounts are solid)???
Old Sep 13, 2002 | 05:48 PM
superdave's Avatar
Originally posted by "mustang23"
I would go with poly on the tranny mount. Who makes solid mounts for the 4.6?
i got mine from Tony at Need 4 Speed. Mutilated the driver side one, so when we put the 99 motor in i put the solid mounts in as well. i believe they were ASP parts. check out http://www.need-4-speed.com/asp.htm and down past all the pullies you will see the mounts. surprisingly, there is very little vibration, but i could feel a difference between from the factory rubber ones.
Old Sep 13, 2002 | 07:12 PM
Road Rage's Avatar
Shake n' Bake
mine does it only after it has been sitting in the rain and i get a mile down the road then when you hit the gas you hear the clucking and it wont accelerate and it does it for 5-10 secs then goes away.
Old Sep 13, 2002 | 07:15 PM
DrDirt's Avatar
Team Geritol Racing
Sounds like tranny mount to me...possibly u joints. If you replace the tranny mount, I'd go with Urethane. If you get too much solid stuff under there, the driveline noise can drive you nuts. Ask me how I know
Old Sep 13, 2002 | 08:14 PM
Hondahunter97GT's Avatar
Red Stripe Beer!
Its because we never finish installing the headers
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
