Heads/Intake ?
yeah i would ditch the Victor, I had it on one of my 302 5 spd cars. Car was a dog even when leaving the line, had to up the starting rshared_pm a whole bunch. Just wasnt a fun car. swapped to a cheap explorer till I found a good intake and it was amzing the difference it felt in stop and go traffic and just cruising at low rpms.
Only 1/4 mile track I know is Gandy Bridge
Not with FI Tommy, you are adding runner length wich will increase bottom end.
THE STICK SHIFT MAFIA Pump gas N/A 349 on some 26x10's http://www.youtube.com/watch?v=NiXjW...ature=youtu.be
I am putting together a turbo set up with AFR 185's, short runner EFI on my Boss 302 with a 76mm BB Turbo. The cam is definitly the key here.
From what I understand with the big head/small cube debate and what actually will be fast and DD friendly, is a cam with low duration and fairly high lift, a good 112-114 lobe seperation and talyor the intake and exhaust events to the needs/use of the motor, N/A, boost or nitrous.
(185's are really not that big a head these days)
There a just so many damn choices out there you can go nuts!
He is building a dail driver N/A street car....
It is an interesting topic and no need for any pissing. This is a tech section.
Small engines like the new coyote 5.0 has heads that flow 300cfm. I understand that it is a 4v engine and is not a direct comparison. But, it is a classic case of big heads/small engine.
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
