Code 98 problem
Old Nov 30, 2010 | 07:57 PM
Superwes98's Avatar
ill check that tomorrow and let u guys know wat happens
thanks tiffany and hurst
if u think of anything else let me know
Old Nov 30, 2010 | 08:01 PM
SVT1996Cobra's Avatar
What?
where did you get that code 98 is for O2's? thats wrong....
Old Nov 30, 2010 | 08:02 PM
Tiffiny's Avatar
I can fix your bullshit
The act snsor :This measures the temperature of the air entering the engine. Which impacts the fuel ratio; the cooler the incoming air is the denser it is. Denser air can utilize more fuel, giving us even greater accuracy in obtaining our desired air to fuel ratio.
maybe the change in weather is making it run worse nowadays
What?
98 = Hard fault is present - Failure Mode Effects Management
The ECM has switched to a fixed calibration value for failed MAF sensor. You need to fix the problem with the MAF sensor circuit
Old Nov 30, 2010 | 08:11 PM
Superwes98's Avatar
not sayin anyone is wrong but the reason i thought it was the o2 was because my actron code reader manual says:
A SYSTEM PROBLEM IS PRESENT CAUSING THE ELECTRONIC CONTROL ASSEMBLY TO OPERATE IN FAILURE MANAGEMENT AND EFFECTS MODE
OR
RIGHT SIDE EXHAUST GAS O2 SENSOR SIGNAL VOLTAGE INDICATES LEAN DURING RICH AIR/FUEL CONDITIONS
OR ELECTRONIC PRESSURE CONTROL SOLENOID -CIRCUIT FAILURE.
since it started running half way decent, for about a week or so i had touched it, and this randomly happened one morning i figured it was o2's since it was random
and are u saying u think its the MAF?
if it is it would suck and be GREAT at the same time
Old Nov 30, 2010 | 08:14 PM
What?
i'll retract what i said since technically it CAN be O2s, but in your your case i highly doubt it. Something is tripping the computer into running in limp mode.
Have you tried switching mass air meters?
Old Nov 30, 2010 | 08:16 PM
  #17 (permalink)
What?
reconnecting the ACT sensor should be a good place to start though...
  #18 (permalink)
Tiffiny's Avatar
mass and act work together to make you car run good .disconnected can also effect the o2s readings
which can make the car buck/ backfire through intake/ run real lean ect
Old Nov 30, 2010 | 08:17 PM
  #19 (permalink)
Superwes98's Avatar
tiffany-
i was told before that it was to measure the air coming in but i didnt know it made that much of a difference so i never bother lookin it up.
ill definitely put that back on some how
Old Nov 30, 2010 | 08:20 PM
  #20 (permalink)
Superwes98's Avatar
i swapped mafs when at the very beginning of all my problems but havent changed it out when this actual problem started two days ago
