Thinking about selling the slobra :-(
Originally posted by "GTi-R B13"
B-I-N-G-O and bingo was his name-o.
Yeah thats my car. I usually park behind the gym. There's almost always a parking space over there
no the real reason he parks there is so he can sit in his car and stare/masterbate at all the hot chick that come out of the gym, Jomar i know your type young man, dont play games with me please.
Nappy head and all is the life for me
Grab my yay and we blowin trees
This is the life god chose for me
Originally Posted by slobra281
Originally Posted by BlackLT1
Jomar does your Cobra not have exhaust pipes out the back, cause I saw a black cobra at usf behind the sundome and wondered if that was yours?
Mark
Mark
-Jomar-
-Jomar-
Guest
Posts: n/a
Originally posted by "99Venom"
Scott, heres a word of advice. Never talk shit about modulars, and then drop off your car at one of said modular owners shops. I took all my aggression out on the test drive. Man those valves float at 7500...
Guest
Posts: n/a
Originally posted by "bitemark46"
Well atleast I don't need heads,cam, and a intake to run 12's!
Take that ya piss drunk cock!
j/k.
Well I had to have a intake because the damn e.f.i. intake just did not work right with the carb. bolted to the side of it where the throttle body used to be !
The cam has a less aggressive profile than the cobra cams.
And finally the mod motor heads and especially the cobra heads still outflow my mildly ported $900 Edlebrock heads. Did you think I was going to keep those nasty factory E7 heads on the car ?
So,
right back at ya' ! Guest
Posts: n/a
Originally posted by "BlackLT1"
Have you guys seen some of this track and soccer girls some are hot as hell and got awesome bodies
Need to go to some of there games lol
but good observation
I'm already close 2 dave and venom? are you talking about venomiss? becouse if so im alot faster than she is
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Marisela
Marisela
“Meditation brings wisdom; lack of mediation leaves ignorance.
Know well what leads you forward and what holds you back, and choose the path that leads to wisdom.”
~ Buddha ~
~ Buddha ~
Originally posted by "Venomiss"
Dave? Lil Dave?? I dunno about that Matt. Besides who broke into the 12's with a bone stock Cobra...?
Your still stuck in the 13's
[quote="Project Pat"]:o :o[/quot]
we run this
we run this
