need help
Old Aug 18, 2010 | 07:13 PM
Superwes98's Avatar
oh and yes i tried another computer
my car wont even start with any other computer
i have a BIG grimlin in my car, i know lol
Old Aug 18, 2010 | 07:16 PM
Superwes98's Avatar
could O2's do this?
Old Aug 19, 2010 | 12:18 PM
Superwes98's Avatar
does anyone have a OBD I code reader?
Old Aug 19, 2010 | 05:18 PM
chevy eater's Avatar
you need a eec code reader Wes.
I don't know it off the top of my head but you can do a search and find how to jump the plug over and check the engine light on the dash for the flashes and get the codes.
The o2's will not make it run like you are describing,I'm at a loss to recommend what to look at to fix it
Old Aug 19, 2010 | 05:22 PM
Superwes98's Avatar
so bought a OBD I code reader and i ran codes for ECA, MAP, and ACT
one is for a sensor that goes to the stock intake which has been unpglugged since i put the intake on, AND thats not the problem
another is for my EGR and thats not the problem
the last one WAS for the ecu memory but i got the fixed and now that code is not comin up anymore
so now for wat the car is doing ---
before when i unplugged the MAF the idle would smooth out BUT NOW when i unplug it, it stays the same. So could it be possible my MAF is bad?
ideas would help........
and by the way since i got this code reader will help anyone else out if u want to know if your throwin any codes and want to use it
Old Aug 19, 2010 | 06:07 PM
Superwes98's Avatar
i think its my MAP sensor
i was confused about wat the reading was exactly
so im goin to check that
how do those go bad?
Old Aug 20, 2010 | 12:37 PM
  #17 (permalink)
Superwes98's Avatar
so my code reader throws the MAP code but its not the MAP. i tried a perfectly good working one today and it didnt help
but i noticed today when i drove it some, AT IDLE ONLY, the rshared_pm didnt jump around too much. but while im driving it still stutters/hesitates randomly
i know everyone likes to prove someone wrong and make them look stupid, and right now im begging someone to call me an idoit AND tellin my wat it is.
Old Aug 20, 2010 | 01:14 PM
  #18 (permalink)
shinysideup's Avatar
TR Balla Donor Supreme
How did you verify no vac leak?
Old Aug 20, 2010 | 01:34 PM
  #19 (permalink)
Superwes98's Avatar
i checked with a hose to my ear and with soapy water
all the simptoms point to the MAP sensor, BAP on my car, but it ran the same when i put the good one on
Old Aug 20, 2010 | 01:36 PM
  #20 (permalink)
Did it make a groan or a hiss?
