87 5.0 starting issue
No I didn't replace the filter but I did pull it out and seen that clean fuel was coming out so I put it back in. I did purge it and clean fuel comes out of the fuel lines just before the rails so I think I'm good now. Just need to get them parts to replace along with the filter too.
fender roller rental
shared_pm me for info
rust from the old tank all up in the injectors causing lean backfire. or ecu not firing injectors. hook a noid light to the injector connecters to see if the injectors are firing. a test light might work.
Update: so I swapped in a stock rail, fpr, and injectors. In order for me to crank it up I need to either spray some starting fluid or stuff a rag with gas on it. Once craked up it will stay on but the backfiring still continues if I gas it a little. If I give it too much gas it will backfire and die out unless I let go of the gas pedal. My next move will be a distributor and see if it helps out. Uggghhh
