alternator fuse for ranger
Old May 25, 2010 | 08:35 PM
BIGBOI's Avatar
Default alternator fuse for ranger
I replaced a bad alternator with a new one and it won't charge the battery.
Is there a fuse that might of poped with the old alternator?
Old May 26, 2010 | 01:30 PM
Pontiac_188's Avatar
Yes there is always a fuse for the Alternator. Need to know what year Ranger to know where the fuse is, but it should be in the Under hood fuse box.
Old May 27, 2010 | 01:50 PM
BIGBOI's Avatar
well I replaced the alternator and the fuse for the alternator and the car dies when I take the jumper cables off.
What could be the problem?
Old May 27, 2010 | 01:55 PM
GNs-r-slow's Avatar
Bondsman
what year?
Old May 27, 2010 | 02:07 PM
BIGBOI's Avatar
Originally Posted by GNs-r-slow
what year?
2000 ford ranger.
The dash volt meter doesn't show fully charge like 1/4 charge
Old May 27, 2010 | 02:24 PM
GNs-r-slow's Avatar
Bondsman
I would check the leads going from the alterator to the solonoid, sounds like a wire is burnt in two or disconnected. Is the battery in the Ranger any good? Even if the alternator isnt working, should start and run on a good battery without a jump
Old May 27, 2010 | 05:25 PM
Pshull727's Avatar
the rangers run a 10ga charge wire and in this wire is a fuseable link that most likely poped one thing you can do and this will also help the truck out is ran a new 4 ga charge wire go to a custom shop and ask for a good 4 ga wire about 3-4 ft should be good and then also do a new engine ground to the battery with 4ga i think this will fix your car.
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
Old May 27, 2010 | 06:22 PM
GNs-r-slow's Avatar
Bondsman
Zactly what I was thinking
Old May 27, 2010 | 06:40 PM
Stoopid Wendy's Avatar
see dick run
^^^Use a fuse or add fuse link wire. Fords like to burn. 4cyl or 6cyl?
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
Old May 27, 2010 | 06:46 PM
Pshull727's Avatar
yeah a fues wont hurt find out what size the it is i think ther 110-130 amp so use like a 125 amp fuse i run a 220 amp on my mustang and im running 0ga to it and a 200 amp fuse
2008 Acura TL DD
