alternator fuse for ranger
I don't know if it would be a good way of checking the fuse but I put the meter on the negative battery and the positive wire that would connect to the battery and got the same as the battery. IS this a good way of checking the circuit is closed?
Man there is only so much info we can help you with i think its time for you to take it to a shop. If you dont know what your doing and your messing with wires you can really f**k up your trunk i see this all the time where people that want to do it themselfs and it ends up costing a ton more cause now your paying to fix all the stuff you messed with. Wiring is not easy to do just be careful. Not trying to be a dick.
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
2008 Acura TL DD
