High idle, high voltage on TPS
Old Jan 17, 2010 | 08:18 AM
Aoshi's Avatar
Originally Posted by LLFordMan
FWIW a copy & paste from FordFuelInjection.com
•Closed Throttle can be anywhere between 0.6-1.0 volts
•Part Throttle is triggered @ 0.04 volts above Closed Throttle
•Full Throttle is triggered @ 2.71 volts above Closed Throttle
vacuum leak?
I'm pretty sure its not a vacuum leak, there are only 2 vac lines I know of, one from each valve cover into the intake.
Anyway im gonna head out and get to work, I dunno about the weather in tampa but in jax its perfect out. 71 degrees with a little wind.
Old Jan 17, 2010 | 09:11 AM
Aoshi's Avatar
Okay guys, I fiddled with the TPS a little more, and was prepared to drill it, but noticed that when it was loose I had a little more playroom, so I stuck some washers inbetween the throttle body and the sensor and I got it down to exactly 1v. Slightly less depending on how hard I release the throttle linkage, its lowest was .96, but sometimes it also hovers around 1.01 if I dont release the throttle linkage hard. I'm going to leave this up to its a cheap multimeter, I'll put my expensive one on it once it returns from saudi arabia or whereever the hell it is.
Anyway, I think i am hearing a small vacuum leak, I'm going to check the diagram and hunt for it later.
The only other problem im getting is that when the car first starts for the first 30-45 seconds the idle still sits around 1100-1200, which isn't bad, but after that first amount of time it drops to 600 rshared_pm stable. Now, I'm not too worried, because the thing has 135k miles on it, but any ideas on whats causing this?
Old Jan 17, 2010 | 09:13 AM
Zman's Avatar
I gota Cheby
iac
Only 1/4 mile track I know is Gandy Bridge
Old Jan 17, 2010 | 09:54 AM
Aoshi's Avatar
Originally Posted by Zman
iac
yeah I came to realize that after I posted. This cars been idling high for over a year so I forgot how it was supposed to act.
