Help needed.
Old Dec 28, 2009 | 03:51 PM
topher469's Avatar
BillionClub Member BISHES
the tank was clean and like I said the psi is great right now. I was thinking injectors or something but I am at a loss. I HATE SN95 intakes and TBs this car is pissing me off. Thanks for the feedback all.
Originally Posted by DrDirt
You also make a foolhardy leap of faith in assuming that the government can execute a program properly when they can't even execute terrorists properly!!!
Old Dec 28, 2009 | 03:56 PM
GNs-r-slow's Avatar
Bondsman
any possible way the hose got kinked when you installed the pump? May have 42 psi at idle but not the volume under load?
Old Dec 28, 2009 | 04:10 PM
chevy eater's Avatar
that was what I was trying to say tommy,pressure under load isn't there
Old Dec 28, 2009 | 04:11 PM
topher469's Avatar
any thing is possible at this point. I will check that too. Thanks
Old Dec 28, 2009 | 06:28 PM
GNs-r-slow's Avatar
Bondsman
I installed a new pump and come to find out the clamp was leaking on the hose inside the tank...chased fuel pressure problems for weeks. I all started when you shut the car off, the fuel pressure would drop to 0 w/in seconds and not holding like it should. new regulator, sent out the injectors and some other stuff before I dropped the tank and found the hose was leaking from my pump install...
Old Dec 28, 2009 | 06:32 PM
302GTS's Avatar
Resident TOB Killer
Although dizzy has been mentioned and replaced... I had a dizzy go bad from Summit about 2 months after putting it in. The car would sputter and backfire under full throttle. Have you hooked up an FP gauge and watched it as you accelerate? That could let you see what's going on at least.
Old Dec 28, 2009 | 06:35 PM
  #17 (permalink)
GNs-r-slow's Avatar
Bondsman
I'll say it again...one of my first mods is a good FP gauge on anything performance
Old Dec 29, 2009 | 10:17 AM
  #18 (permalink)
fuelie327's Avatar
plug wires , cap and rotor ? Is it missing then backfiring? Set timimg with spout conector disconnected? connected will be to far advanced
Old Dec 29, 2009 | 10:50 AM
  #19 (permalink)
Stealth Mode's Avatar
Still CREEPIN
Have you tried putting a carburator on it? Lol
Good luck dude!
TurboRAM Member #5
24psi & Stable
GET SOME
Old Dec 29, 2009 | 12:23 PM
  #20 (permalink)
302GTS's Avatar
Resident TOB Killer
Good luck dude!
In before 95cobrasvt....
