347 Stroker!!! (in seek for advice)
Old Dec 19, 2009 | 04:01 PM
  #31 (permalink)
GNs-r-slow's Avatar
Bondsman
[quote=fuelie327;7344314]
Originally Posted by GNs-r-slow
no , I meant you can build the whole thing for around 3k +/_ without using a dart block, I was agreeing with you
Yep...unless I was shooting for 800+.....I would save the money on the block
Old Dec 19, 2009 | 06:00 PM
  #32 (permalink)
stangman289's Avatar
What are you confused about? Is the rotating assembly already in a block? or do you have a bunch of parts that needs assembled? What are you goals for the car? Hp? turbo? spray? If you already have pistons and know the compression ratio, that will make your final plans depending on compression
What do you meen already in the block? This add is about what block to use? No spray. NA Right now. Turbo when cash flows in.
Stangman289/Tyler (352)556-8024 Call/Text anytime!!! [/COLOR][/COLOR]
Originally Posted by Ashy-Larry
^^^Yea, we all knew it would be a matter of time b4 the Honda crowd realized Hondas weren't cool and wanted to jump on the drift wagon.
Old Dec 19, 2009 | 08:37 PM
  #33 (permalink)
GNs-r-slow's Avatar
Bondsman
He said he had so Brian's old car so I thought it may already been assembled in a block already. That's what I meant....I'm not the confused one..........today
Old Dec 20, 2009 | 12:03 AM
  #34 (permalink)
Iraq&Roll's Avatar
How much are you into the 347 kit now?
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
Old Dec 20, 2009 | 04:52 AM
  #35 (permalink)
notchbackman's Avatar
As far as money, not much for the rotating assembly 1153.00. Have not bought the Carb intake yet. Only bought the Z303 cam. Going to use the Heads off of the that are on there.
Old Dec 26, 2009 | 05:46 AM
  #36 (permalink)
Iraq&Roll's Avatar
Did you make a choice yet?
Old Dec 26, 2009 | 06:14 AM
  #37 (permalink)
GNs-r-slow's Avatar
Bondsman
Originally Posted by fuelie327
whats so special about " roller " blocks? Cant you make them all roller blocks ? That 306 I had wasnt a roller until I drilled and threaded the holes for the lifter retainer . Can't you do that to them all?
The only thing special is they are especially weak. you have to run a reduced base circle cam, if you run roller in an non-roller block
