squeak/screetching noise
Old Dec 15, 2009 | 03:12 AM
GNs-r-slow's Avatar
Bondsman
A main bearing will screatch like you describing also. What do you know about the motor Harold?
Old Dec 15, 2009 | 03:18 AM
GNs-r-slow's Avatar
Bondsman
I'd put it on jack stands ;ike Fuelie was saying and have someone in the car were you can crawl around and diagnos it.
Old Dec 15, 2009 | 04:47 AM
harold harper's Avatar
h9
25psi at idle and 55 psi at mid throttle.
Old Dec 15, 2009 | 10:09 AM
fuelie327's Avatar
input shaft doesnt turn when its in neutral
Old Dec 15, 2009 | 10:12 AM
fuelie327's Avatar
Originally Posted by GNs-r-slow
Because if the car still rolling the input shaft still turning
input shaft doesnt turn in neutral
Old Dec 15, 2009 | 10:15 AM
fuelie327's Avatar
if the engine is off and tranny in neutral the crank isnt turning , so the tob cant be turning. the clutch is bolted to the flywhhel wich is bolted to the crank.input shaft is splined,I'd bet on it not being the TOB . something has to be hitting the driveshaft or one of the backing plates on the brakes
Old Dec 15, 2009 | 12:11 PM
  #17 (permalink)
h9
let you guy know here in a little.i am going to jack up the back and put it stands .test run on stands to c if it makes noise,and turn the wheels with out the motor running.
Old Dec 15, 2009 | 12:20 PM
  #18 (permalink)
stealth gt92's Avatar
oh no dont tell me were not gunna be able to run now hahaha i hope its okay.
Old Dec 15, 2009 | 12:41 PM
  #19 (permalink)
h9
we will run squealing or not.motor loud enough to drown out the noise lol!hopfully it will be straighten out by the weekend.
Old Dec 15, 2009 | 02:24 PM
  #20 (permalink)
h9
FIXED!! put it up on jack stands and ran it.noise was at the rear tail shaft of the trans.pulled the drive shaft,checked the ujoints,and they were good.i think what was causing it was due to the fact the was trans was low on oil when i changed out the engine(level plug was loose).so i filled it up to the level plug.i think what happen the rear bearing dryed up and won"t let the oil past the yoke and beaing.since i pulled the drive shaft out it allowed oil to get past it.reinstalled drive shaft in car and no more noise.ran the piss out of it.i even got race when i was out test running it.old harley bike i think.boy was that guy pissed.lol!! thanks for the input guys.
