Need help??
Old Nov 24, 2009 | 07:46 AM
Jesus24's Avatar
Default Need help??
i have a gt40 from a explorer and i have 302 from a ford bronco and i personally dont kno shit about mustangs.. what do think will work out better for a 2001 ford mustang??? tell me what will be easier and cheaper
Old Nov 24, 2009 | 09:06 AM
95coBraSVT's Avatar
banana republic
Neither. You need a 4.6 for ease of installation and cost savings.
*edit* I thought Jesus knew everything? My world is crushed now.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Nov 24, 2009 | 10:28 AM
Hurstmeister's Avatar
That depends. If its a 3.8 v6 car then a 4.6 would require a different k-member and the 5.0 would be a direct bolt in because the 3.8 and 5.0 use the same k-member. 4.6 also uses hydrastat brake booster off the pwr steering pumps. If its a V6 car then it will have vacuum power assist on the master cylinder.
Is the car a GT or V6?
If GT then you need another 4.6 and make sure its a 99 or newer 4.6 from a Mustang. If from a Truck or other car then should be a 2002 or later engine to ensure it has the same PI heads that the 99 - 04 Mustangs has.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Nov 24, 2009 | 03:28 PM
GNs-r-slow's Avatar
Bondsman
Originally Posted by Hurstmeister
That depends. If its a 3.8 v6 car then a 4.6 would require a different k-member and the 5.0 would be a direct bolt in because the 3.8 and 5.0 use the same k-member. 4.6 also uses hydrastat brake booster off the pwr steering pumps. If its a V6 car then it will have vacuum power assist on the master cylinder. Hurst
What all years do this appl Encyclo-Miester? Goood info thur
Old Nov 24, 2009 | 03:37 PM
SVT1996Cobra's Avatar
What?
^ALL 94-04 v6 cars use the same k-member as a 5.0
Old Nov 24, 2009 | 03:56 PM
$hawn's Avatar
lives in a glass house
Orly?
Old Nov 24, 2009 | 03:58 PM
What?
as far as i know, and the v6 4r70w will bolt up to a 5.0 as well. getting it to work properly is another thing i would guess
Old Nov 24, 2009 | 04:04 PM
GNs-r-slow's Avatar
Bondsman
Originally Posted by $hawn
Orly?
Do you know something diifferent? Or new info to you? My nephew is looking to do a swap
Old Nov 24, 2009 | 04:22 PM
$hawn's Avatar
their are two k-members. a 94-95 and a 96-04. engine size didnt matter, only the year.
Old Nov 24, 2009 | 06:10 PM
Jesus24's Avatar
nice oke thnx ppl it is a v6 soo what ur saying is the mottor mounts will fit right in i dont get it???
