Coule use some help with my starter
Old Nov 10, 2009 | 11:22 AM
302GTS's Avatar
Resident TOB Killer
Originally Posted by Stealth Mode
The only times I have ever had solonoids stick in my Mustangs, The car will try to start itsself while running. Ask Gns-r-Slow,... He helped me figure out why my white '85 coupe kept doing that shit. So I dont think its you're starter solonoid. Good luck.
Thanks, I've ignored the issue for months, but it's really starting to get on my nerves.
Old Nov 10, 2009 | 01:02 PM
Stealth Mode's Avatar
Still CREEPIN
He caught my ninja edit!!! Lol
TurboRAM Member #5
24psi & Stable
GET SOME
Old Nov 10, 2009 | 01:55 PM
302GTS's Avatar
Resident TOB Killer
Old Nov 12, 2009 | 10:23 AM
302GTS's Avatar
Resident TOB Killer
Hurst, still havn't checked out those battery cables and all. The rain kind of made me change yesterday's plans to do that. I've noticed today that I'm able to pull the ignition cylinder in and out a little bit, not just the little black piece. It slides out of the steering column about 2cm if I pull on it from the black tab piece. Any idea if that could be causing my issue?
Old Nov 12, 2009 | 01:09 PM
Hurstmeister's Avatar
This is not my area of expertise,.. so please dont hold this advice as gospel and say Hurst said so.. so it must be right. But I dont think so. The ignition cylinder itself has no electrical connections on the 94/95 cars. It only engages a mechanical arm down in the column that actuates the ignition switch. The switch itself can become faulty,.. but its like any other switch,.. its either on or off. Its different then the Fox ignition switches. The later 96 - 04 cars had a sensor wire for the PATS system to detect the chip in the key. But even the PATS system would have no effect on the starter itself. It still allows the engine to turn over.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
