i'm stumped ?!?!?!?
Old Nov 1, 2009 | 12:51 PM
GT5.0HO_STANG's Avatar
Bred2Run
Default i'm stumped ?!?!?!?
ok guys need help tryin to figure this one out.
car symptoms: rough idle like as if were misfiring but its not main thing is overheatin then drops temp then overheats and then drops again and then just stays high
what i've done so far: new aluminum radiatior, water pump, replaced all hoses and radiator cap
my guesses which i havent tried yet but are thinking: radiator fan gone bad, heater core (maybe bypassing it) coolant temp sensor
what do you guys think before i attack the car again when i get it back???
Old Nov 1, 2009 | 01:09 PM
$hawn's Avatar
lives in a glass house
make sure the fan actually turns on..... but the problem kinda sounds like a head gasket.
Old Nov 1, 2009 | 02:04 PM
91Notch's Avatar
Is workin on his car
Old Nov 1, 2009 | 02:05 PM
Bred2Run
thought of that but i didnt think it would be an issue this soon with only 110k on it and never driven hard only once in a while
Old Nov 1, 2009 | 02:07 PM
Bred2Run
no smoke either just noticing the coolant res. goin low and having to fill it up every couple of weeks thats why i also didnt think it was a head gasket but it could be.....how could i test that out to confirm its a head gasket????
Old Nov 1, 2009 | 02:21 PM
$hawn's Avatar
coolant leak down test will tell you. if you dont have the tools to do this, simply checking the plugs will go a long way
Old Nov 1, 2009 | 02:25 PM
kanji1jz's Avatar
jza70r
Check your oil. If it looks like chocolate milk then you have coolant leaking inbetween the coolant and oil passages. The other thing is there may be air in the system still. Did you purge the system before you capped the radiator?
89 jza70r
3" exhaust w/ apexi muffler
xs engineering intercooler
sportmax 962 17x9 (r) and 17x7.5 (f)
kelly charger hpt tires
eibach lowering springs
kyb struts
sneed speed shop dual electric fans
max steel solid engine and trans mounts
walbro 255 fuel pump
custom 2.75" intercooler piping
R.F.L. bov (not a big fan but it gets the job done for now)
Old Nov 1, 2009 | 03:31 PM
Bred2Run
purged it angled it bubbled it put the heater as well......last few oil changes didnt notice any milky oil so i kno thers no coolant in the oil
did a pressure test several times and the gauge goes down but i still cant find any leaks anwhere. i was wondering if the heater core is clogged or had a leak would it drain out through the ac drain or build up inside ??? (my carpets arent wet on either side)
Old Nov 1, 2009 | 05:26 PM
GNs-r-slow's Avatar
Bondsman
Headgasket can blow between coolant and combustion hense pressure going down on pressure test. You wont see the leak its internal. What year car are you working with?
Old Nov 2, 2009 | 03:32 AM
fuelie327's Avatar
wha t about the stat ? Does it have one? could be sticking then opening. Simple stuff first
