idle issue with new t/b 1100 rm cant adjust.
Old Sep 3, 2009 | 09:11 AM
stealth gt92's Avatar
Default idle issue with new t/b 1100 rm cant adjust.
put a new bbk t/b and spacer on the car yesterday and now the idle sored up to 1100 rpm i tried to adjust it because usually t/b have that screw thats on the t/b so you can adjust there is a bolt fixed there were its suppose to be i dont know what the hell to do.
Old Sep 3, 2009 | 09:17 AM
500HPLX's Avatar
What does it do when you disconnect the IAC valve?
Have you diconnected the battery and then set the idle?
What procedure are you using to set the idle?
Other than the idle speed how does it act?
Air leak?
Old Sep 3, 2009 | 10:19 AM
idk ill have to check i have disconnected the battery and then reconnect let it run it runs fine idles fine no check engine light just idles at 1100 rpm and slow to come down under driving conditions. with all my other cars there was a screw to adjust the idle on the actual throttle piece but this one is like just a boltlike fixed and i did all new gaskets when i put it on? and i capped that little valve buy the sensor because the breather from the valve cover was short and wouldnt fit?
Old Sep 3, 2009 | 10:37 AM
just let it run uncapped the little valve no difference im pretty sure the only way i can fix is manually by trying to turn that damn bolt or something im going to try i might have to have someone look at it to get a second opinion i dont know.
Old Sep 3, 2009 | 11:51 AM
500HPLX's Avatar
That is weird it doesn't have a set screw for the idle.
Old Sep 3, 2009 | 12:07 PM
GNs-r-slow's Avatar
Bondsman
TPS? come on now....back to basics!
Old Sep 3, 2009 | 12:53 PM
i took it off took the bolt out and bought one with a head so i can adjust it.
Old Sep 3, 2009 | 01:06 PM
500HPLX's Avatar
Good deal.
Old Sep 3, 2009 | 01:31 PM
idles fine now but check engine light wont go off tried on hooking the battery looking at all of the sensors idk what the fuck is going on.
Old Sep 3, 2009 | 01:59 PM
Na306StAnG's Avatar
Flowmaster nut swinger
How long did you leave the battery disconnected for?
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
