Question on old ass 302
Old Aug 28, 2009 | 12:45 PM
TurboRanger91's Avatar
it's always something
Default Question on old ass 302
I'm not a hundred percent sure, but I think the 302 that's in my ranger is like a sixties model. I'm still waiting to hear back from the guy I bought it from. The drivers side head started ticking last night. First off, I was told that I can run the motor without the valve cover on to try and narrow it down... Is that correct? Second, how interchangable are the heads throughout the years? For instance, could I run a later model head oN this old motor?
91 ranger, 88 tc 2.3 turbo, stroked, bored, 5.5" crower connecting rods, wiseco 8.0:1 dished pistons, total seal .030 rings, fully ported iron big valve head, racer walsh turbo roller cam, bobs log, holset wh1c, fmic, full 3" exhaust. not really a whole lot left to do.
93 explorer 4x4
Old Aug 28, 2009 | 01:31 PM
GNs-r-slow's Avatar
Bondsman
IMO the early heads are better (smaller comb chambers). The early heads have adjustable rockers not bolt down. Rockers prolly just need to be adjusted
Old Aug 28, 2009 | 01:33 PM
You think that's what's causing the noise?
93 explorer 4x4
Old Aug 28, 2009 | 01:37 PM
Stealth Mode's Avatar
Still CREEPIN
Look at the casting on the side of the block C=60's D=70's E=80's F=90's
TurboRAM Member #5
24psi & Stable
GET SOME
Old Aug 28, 2009 | 04:27 PM
95coBraSVT's Avatar
banana republic
Yes, later model heads will fit on that motor. BUT, you need to make sure they are from a carbed motor, if you're running a carb. Also, I have seen rocker fulcrum's go bad before and cause ticking. I replaced the rocker and fulcrum, and the ticking was gone. But that was years ago.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Aug 28, 2009 | 04:28 PM
GNs-r-slow's Avatar
Bondsman
Very good possibility....the rockers are adjustable, and stock have lock nuts and over the years they get wore out and can / will back off
Old Aug 28, 2009 | 04:31 PM
GNs-r-slow's Avatar
Bondsman
Why is that...people put carbs on FI heads daily. Aftermarket aluminum heads dont come FI or carbed versions, right?
Old Aug 28, 2009 | 04:46 PM
harold harper's Avatar
h9
u are correct there the main diffrence is in cam selection and intakes.they have ecm freind cams ....so they say.
Old Aug 28, 2009 | 05:06 PM
You were right! I had one rocker that had backe out a bit. Simple 10 minute fix.
93 explorer 4x4
Old Aug 28, 2009 | 05:11 PM
GNs-r-slow's Avatar
Bondsman
Advanced used to sell those rocker nuts cheap by 2's...It may be time to throw some new ones on it. Glad I could help
