Any one know bout lincons??
Old Jul 3, 2009 | 12:19 AM
tony122's Avatar
Originally Posted by Duceanahalf
Wow....
Anyway. To replace the airbags With springs you remove the air bags and all the stuff for them, grab a pair of rear springs out of a 79-02 crown Vic, grand marquis, or towncar, and put them in. The spring perches are already there
The watts link cars (98+) use the watts link to laterally locate the axle since the control arms are parallel the springs are the same before 2003.
To install a watts link rear you would have to take the rear section of the frame off a 98+ car , but swapping the entire frame is less work. And not worth it unless you want it. A panhard bar is just as effective
Awsome you the man then!!!i went online they have a kit for 300. i rather go to the salvage yard and get them. how about the front are them coil springs already or are they bags 2?? one more dumb question the shocks absorbers were the hell are they gona go?? i have not raised the car yet but since you done it before you be the right person to ask.....Thankls to all for the quick replys
Old Jul 3, 2009 | 01:39 AM
tony122's Avatar
never mind..Just went to lincolnland.com and saw pics of the rear suspension..
Old Jul 3, 2009 | 11:22 AM
Duceanahalf's Avatar
is doing your girlfriend
fronts are coil springs, not bags. rear shocks stay in the same place.
if you dont want to pull them from a junkyard you can still buy the springs form a parts store or the ford dealer, but from the dealer you will need to order them for like a 99 crown vic.
or you can order aftermarket race springs for $50 each
Old Jul 3, 2009 | 05:01 PM
tony122's Avatar
thank you for the info.
