Engine Starts then won't start 2nd Time
Old Jun 30, 2009 | 07:37 PM
Tiffiny's Avatar
I can fix your bullshit
sounds like ecm
Old Jun 30, 2009 | 09:19 PM
GNs-r-slow's Avatar
Bondsman
Originally Posted by Airborne
Thank you all for the input, here is the latest. I believe it is getting too much fuel.
Has a fuel pressure gauge been installed to verify what the pressure is? Also when it wont start to be able to verify pressure.
Old Jul 1, 2009 | 02:28 AM
fuelie327's Avatar
it actually sounds like a bad fuel pump.Sounds like when the pump cools down it starts back up.You need to check fuel pressure when it dies and when you crank it and it wont start
Old Jul 1, 2009 | 02:40 AM
GNs-r-slow's Avatar
Bondsman
Great idea...
Old Jul 1, 2009 | 04:54 AM
19-Camaro-88's Avatar
Posts most when drunk
The pump is brand new and has a autometer FPG. It reads perfect pressure. All the msd is brand new. All I can guess is either the distributor or the ECM.
-Miles.
Old Jul 1, 2009 | 02:26 PM
Airborne's Avatar
Just swapped the distributor and same problem. Thought I had a spare computer to try but forgot it was bad. Will have to somehow manage to borrow one to check out if that is it or not.
Old Jul 2, 2009 | 02:25 AM
  #17 (permalink)
GNs-r-slow's Avatar
Bondsman
Have you checked it....dont count on it being good because its new, MSD's quality has been going down over the last couple years
Old Jul 5, 2009 | 07:04 PM
  #18 (permalink)
23tstang's Avatar
if in doubt... TURBO IT!!
^^ +1 new does not equal good. check it ALL OUT
TB CUSTOMS. top notch work shouldnt cost you top notch money. we'll beat any other companys custom fabrication and weld quotes and support you with an amazing warrenty.
727-768-2967 call or text
facebook us
http://www.facebook.com/home.php#!/h...059440077&ap=1
Old Jul 6, 2009 | 03:14 PM
  #19 (permalink)
fuelie327's Avatar
today , 2 fuel pumps in the box , garbage....last friday ,3 master cylinders , garbage ....last tuesday 4 fucking 4 alternators , new not reman,garbage....it happens every day
Old Jul 9, 2009 | 03:21 AM
  #20 (permalink)
EsCoRtLvR's Avatar
Escort Connoisseur
I Have that same problem with my mustang with pretty much the same setup you have. Needs to be tuned, Temporary fix was a toggle switch for the fuel pump relay.
When this happens to your car pull the fuel pump relay out, start the car, then put the relay back in. If that works you need to go have it tuned somewhere.
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
