a little help here guys
Old Jun 28, 2009 | 07:59 PM
GNs-r-slow's Avatar
Bondsman
Didnt think it could be done, I have 10's with 6.5"bs Dragstars with a 275/60 and its close
Old Jun 29, 2009 | 11:41 AM
19-Camaro-88's Avatar
Posts most when drunk
I had draglites 15X10 with a 6.5 bs and MT 275.60.15's and I had to use the BFH mod and a 1/4 inch spacer to make them fit without rubbing when I went into a corner.
I thought the SN95s had more clearance than the foxes? I've seen 315's on a stock axle SN95
-Miles.
Old Jun 29, 2009 | 12:12 PM
Hurstmeister's Avatar
They do. You can stuff a 325 tire back there and the only issue will be with the quad shocks. If the car is lowered you may have some rubbing on the inside fender well,.. but most of the time 315's on a 10 - 11 inch wheel with a 6.5 BS fit fine.
12inch with a 8.5 inch BS is not gonna work. It will rub like hell. Will need a 2 inch spacer to bring it away from the inner fender well. I dont like running wheel spacers on rear wheels. Asking for problems if you dont use thicker longer studs.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Jun 29, 2009 | 12:17 PM
I'm with you on that one. 275/60 is as large as you can stuff back there on a fox and even then you have to roll the outer lip and do the BFH mod to the inner fender well to keep from chewing up the tire. I've seen 315/35 17's on the back of a fox,.. but it was tight and I'm sure some clearancing was done.
Hurst
Old Jun 29, 2009 | 01:25 PM
BeAcH BuM'd's Avatar
SS=SuperSlow?
Whats a BFH mod?
Old Jun 29, 2009 | 03:28 PM
SVT1996Cobra's Avatar
What?
"Big Fucking Hammer"
Old Jun 29, 2009 | 03:56 PM
  #17 (permalink)
GNs-r-slow's Avatar
Bondsman
Exactly...thats why I'm saying there is NO way they had a 12" wide wheel with 8.5" of backspace on a stock axles Fox
They do...thats why asked if it was a stock axle Fox or mini-tubbed. Because if it fit on a standard axle Fox there is no problems with it fitting on an SN-95
Old Jun 29, 2009 | 04:03 PM
  #18 (permalink)
ruler's Avatar
97 gt
i am having trouble with the brake lines and ebrake cable. I got a spacer for the front (like 1/4) and I still have some rubbage on the caliper. I got longer studs and am working on it. If somebody could post a pic of a ground caliper (the right way) it would be helpful.
Old Jun 29, 2009 | 04:08 PM
  #19 (permalink)
ruler's Avatar
97 gt
i got no fender issues dont even need to roll it
here is a link to pics of the fox with them on it
want to trade 5 lug welds (mustang) - Need2speeD.com
Old Jun 29, 2009 | 04:27 PM
  #20 (permalink)
GNs-r-slow's Avatar
Bondsman
feeler ad mini-tub 90 fox - Need2speeD.com
Here's the link that tells you the car is mini tubbed, glad you got them to fit
