aod or t-5
Old Jun 6, 2009 | 04:05 AM
froggiemustang's Avatar
a fan/looker
Default aod or t-5
i found a aod rebuilt and 2400 stall torque converter for $450 but i also found a t-5 for 300 im looking at something that will give me a 4th or more but not a hard job i mean i know that would be the aod but how hard really is doing the clutch?
Old Jun 6, 2009 | 05:25 AM
500HPLX's Avatar
Where are you doing the work?
A AOD is a big heavy pig working under a car on jack stands. I know!
I like shifting gears.
Go 5-speed!
Old Jun 6, 2009 | 05:54 AM
harold harper's Avatar
h9
5 speed on 90% street duty cars and is this going to be your daily driver?
Old Jun 6, 2009 | 10:59 AM
a fan/looker
yea its my daily driver if i do decide to do this im gonna do this in my drive after i get my mothers suburban outta the drive with no radiator cause of a deer
Old Jun 8, 2009 | 04:53 AM
IamSuprAwsum's Avatar
Blasphemer
I would go with the 5 speed as IMO they are just more fun to drive. You might be looking to spend slightly more then 450 if your going to go from an auto to a stick as you will need not just the tranny, but also the 3 pedal setup, clutch cable, bellhousing, shifter fork, flywheel, and clutch.
(USER WAS BANNED FOR THIS POST)
Old Jun 8, 2009 | 08:04 AM
Stealth Mode's Avatar
Still CREEPIN
C6!!
TurboRAM Member #5
24psi & Stable
GET SOME
Old Jun 8, 2009 | 10:59 AM
a fan/looker
i knew i would have have 2 pay a little bit more for the other accesories for the t-5..and yea i believe that stick is more fun thats what i started to learn to drive with still got the car just need an engine its a ricer but hell its a good car on gas and good for road trips its a 98 nissan sentra 1.6L anyone know something about those and can get an engine let me know....but other then that.... i wanna get the stang to go fast with being able to save something on gas an not be at 3k on the tach for only going 60 and whats a c6
Old Jun 8, 2009 | 11:44 AM
Blasphemer
5 speeds typically are a lot better at cruising speeds than autos just because they have higher top gear ratios. A c6 is a 3 speed non-OD auto they used to put in heavy duty trucks and behind bigger engines in cars.
Old Jun 8, 2009 | 03:07 PM
460 TZILLA's Avatar
THROTTLE STEER
The car is gonna be set up with a T5..I have most of the stuff to set up the car its just a matter of time...........
Talk softly but Drive a big block
Old Jun 9, 2009 | 04:59 AM
Blasphemer
Nice
