I need a little help with a valve-train noise.
Cheap add on I use on my car and on friends car's in the past.
The EGR delete and the EGR block off plate.
RJM Injection Tech » EGR Eliminators
I'm going to get the 65mm delete plate whenever I get around to it. Right now I just need to get it running.
Helmut
Helmut
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
Car is running excellent! Threw a little base idle tuning on it before work. Runs perfect, better than with the 19's. Runs cooler than before too! I'm very pleased with it, just need to track down what I suspect is a small exhaust leak.
I let it breath a little on my way home, just slapped second for a second...nothing much, less than half throttle. She's quick - moved out quicker with that little bit of throttle than it did before under full bore lol.
I had more noise than I would have liked when I put mine back together. The whole top end was new and everything changed. I added a new roller cam, new OEM roller lifters and roller rocker arms. The arms were a little noisy and from what I hear, some people say the Comp Cams XR roller cam series I used are noisy as well. (aggressive lobe ramps??????)
Anyway, I went thru the rocker settings like 3 times before I was happy.
