Turbo AWD '32 Ford Coupe
Old May 27, 2009 | 04:05 PM
Stealth Mode's Avatar
Still CREEPIN
Originally Posted by jchauncey
thats some weird looking shit, i have never seen one of those engines b4. is the water pump under the passenger side of the block?
TurboRAM Member #5
24psi & Stable
GET SOME
Old May 27, 2009 | 04:58 PM
longfellow2's Avatar
FORE:sight
Thats an external oil-pump for a dry sump system.
Originally Posted by Epstein
Old May 27, 2009 | 05:28 PM
Still CREEPIN
hmmm, for some reason it looks like an electric waterpump. in-genious invention none the less
TurboRAM Member #5
24psi & Stable
GET SOME
Old May 28, 2009 | 05:57 AM
MiDiablo's Avatar
Awesome vehicle!
Old May 28, 2009 | 06:10 AM
Duceanahalf's Avatar
is doing your girlfriend
the water pump is a water pump. its mounted there cause you couldnt mount it to the front with the blower there. the oil pump is the thing there driven off the belts.
Old May 28, 2009 | 07:05 AM
Just Dave's Avatar
Do It In The Dirt
flatheads use 2 water pumps stock. One on each bank of cylinders (the V8 was derived from the old flathead 4 cylinder). Obviously there's no room for 2 water pumps in the front, much less one, so he routed it through the freeze plugs on the side of the block. Hell, there may be another water pump on the other side.
Its irrelevant, because that badass looking motor probably makes 300hp. Its basically 8 old lawnmower motors that share a crank. The old saying is flatheads are the most efficient way to create noise and smoke without the annoying side effect of horsepower.
29 Hard and Single
My Rail Buggy
Old May 28, 2009 | 08:47 AM
  #17 (permalink)
IamSuprAwsum's Avatar
Blasphemer
Im not too familiar with it. I read something about it in Hot Rod a couple of years ago. There was some guys a while back that used to like using nostalgia stuff and hot rod the shit out of it. They liked using flatheads like that one. That particular one I believe is pushing over 20 psi I want to say and puts out around 500hp. Not too shabby for an engine design from the 30's.
edit. my mistake. I cant seem to find any documentation on where I saw the 500 hp flathead. I dont have any info on the one I posted. Still 300 hp isnt bad for a flathead either.
(USER WAS BANNED FOR THIS POST)
Old May 28, 2009 | 08:56 AM
  #18 (permalink)
Still CREEPIN
what cars did those engines come in?
TurboRAM Member #5
24psi & Stable
GET SOME
Old May 28, 2009 | 09:00 AM
  #19 (permalink)
Blasphemer
so it is the waterpump.... what cars did those engines come in?
Here is some information.
Flathead Model ID chart
Old May 28, 2009 | 03:15 PM
  #20 (permalink)
smokeshow's Avatar
Slower Than Dial-up...
Nice!
