signal wire
Old Jan 22, 2002 | 10:03 AM
runningonempty's Avatar
does anyone know what the signal wire coming from the o2 sensor into the ECU on a 98 Stang is?? I need to install my air fuel ratio gauge and noone seems to know...
Old Jan 22, 2002 | 10:14 AM
stangerang's Avatar
whoopdy fucking do!
here ya go-- this is off the auto meter site so it should be right....
94-96 Mustangs
There are two options for this particular hookup being the left or right oxygen sensors. The best spot to make this hookup is right sensor at the PCM. This is located above or behind the passenger side kick panel. There will be a 104-pin connector in that location. To hook up to the left sensor go to pin 43 which is a red wire with a black stripe. In order to hook up to the right sensor go to pin 44 which is a gray wire with a light blue stripe.
97-99 Mustangs (2000?)
There are two options for this hookup as well again its the left or right sensors. Locate the PCM which is above or behind the passenger side kick panel. Look for the 104-pin connector. For the left sensor you will go to pin 87 which is a red wire with a black stripe. For the right sensor you will go to pin 60 which is a gray wire with a light blue stripe.
200 points away from a 300
Old Jan 22, 2002 | 01:22 PM
thanks Ill let you know if it is right here directly thanks again!!!
Shinmantis
Aug 17, 2000 11:24 AM
