questions on rocker arms
Old Apr 1, 2009 | 06:55 PM
bottlefedLX's Avatar
Don't be so angry
Default questions on rocker arms
I need a set of roller rockers. I am looking at 1.6 ratio, 3/8" stud for Trick Flow Twisted Wedge heads. I am also getting the TFS stage 1 cam (duration 221/225 with .499"/510" lift.) The car is supercharged (9 PSI) with a Track Heat intake, 75mm throttle body, and 42# injectors.
I am leaning in the direction of the Trick Flow. But, I am looking to a cheaper alternative. I was considering the Jegs set. I do not plan on making more than the 500hp (at the crank) range by the time I am done, although 450hp is more realistic.
Any suggestions?
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
Old Apr 1, 2009 | 07:41 PM
Na306StAnG's Avatar
Flowmaster nut swinger
I have ran these rockers before with no problems. Back then my car made 336 hp to the wheel.
http://cgi.ebay.com/ebaymotors/1-6-3...Q5fAccessories
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Apr 1, 2009 | 07:51 PM
Stealth Mode's Avatar
Still CREEPIN
Originally Posted by Na306StAnG
Back then my car made 436 hp to the wheel.
**Fixed**
(u forgot the spray)
shaun, i need to talk to u bout something, call me wen u get a chance.
TurboRAM Member #5
24psi & Stable
GET SOME
Old Apr 1, 2009 | 07:57 PM
Na306StAnG's Avatar
Originally Posted by Stealth Mode
**Fixed**
Back then I was Na306stang with an AOD yo
My mustang at sunshine raceway Video by Shaun / Na306StAnG - MySpace Video
Largo fl 33773
MV#72427
Old Apr 2, 2009 | 07:55 PM
Don't be so angry
Thanks for the info, Shaun, I'll check them out. I am leaning towards a set of Harland Sharp roller rockers.
John
Old Apr 3, 2009 | 02:55 AM
Na306StAnG's Avatar
I saw that over on Mafia. Local and cheap is the only way to roll!!
Largo fl 33773
MV#72427
Old Apr 4, 2009 | 05:41 PM
Don't be so angry
Does anyone on here have Twisted Wedge Heads? If so, what rocker arms are you using? I am thinking about a set of Harland Sharp rockers, but they are not the Twisted Wedge specific rocker, just the SBF (there are 2 different part numbers). Gearhead also has a set of PRW rockers that I had my hands on this afternoon(very nice), but they are not specific to a certain Ford head. I know I am not the only person to ever have a set of TW heads, so am I making this more complicated than it needs to be?
John
Old Apr 4, 2009 | 05:44 PM
Don't be so angry
Also, thanks Mitch for hooking me up this afternoon.
John
Old Apr 6, 2009 | 03:03 PM
Na306StAnG's Avatar
I could be wrong but I didn't think the T/W head took a specific rocker.
Largo fl 33773
MV#72427
Old Apr 6, 2009 | 06:56 PM
MiDiablo's Avatar
I've got TW heads, but they came with the TW roller rockers, pushrods, cam, etc. So I'm no help,
