Carb Help?
I'd actually tried that too man. But the solenoid on the nitrous side is ALL UP in the throttle bracket and linkage! It's perfectly fine on the passenger side, go figure.
I may look into shorter carb studs I guess. I'll need to be placing an order for some throttle balls from AED anyways, so guess I can put together a small order; even though I was trying to get away w/not spending any cash on the car to put it together!
Duce,
Or just get shorter studs.
The choice is yours.
I'd prefer to run the nitrous manifold. A.) because I own it. B.) because it looks much better/cleaner/neater than anything else I've seen. c.) because it's what the hell I want to do!
So far I think my resolution is to buy the 1" spacer, keep these shims/gaskets to make up for any clearance issues, put the manifold on at the bottom of the stack (at intake), cut the bottom of the throttle bracket on the carb, and then I need to do something w/the throttle spring hitting the underside of the filter element....
Thanks fellas!
