valve spring gurus
Old Mar 6, 2009 | 02:13 PM
red vert's Avatar
welcome to Tampa Ricing
Default valve spring gurus
My new heads are currently set up w/ k-motion k-850 springs rated for about 165lbs when set at 1.85". My cam (hydraulic roller) states about 120 on the seat, will this extra lbs come to haunt me in a bad way? I know too little is bad and way too much prematurely wears parts, is this too close to borderline?
Old Mar 6, 2009 | 02:25 PM
GNs-r-slow's Avatar
Bondsman
Worst case it would wear the lobes off. No worries
Seriously... probly wont rev as freely as it should, kinda like draggin an anchor
Old Mar 6, 2009 | 02:51 PM
red vert's Avatar
actually worried if the rollers will keep enough pressure for them. This is just the opposite of the last conversation we had Tommy. I may have to look further into a hybrid setup, or just get some diff springs.
Old Mar 6, 2009 | 04:19 PM
GNs-r-slow's Avatar
Bondsman
Go solid and be done with it. I dont see the lifters as an issue for you, specially your not gonna turn it 8,500rpms. I Dont recall any lift or spring pressure spec recommendations on lifters. There was a post a while ago were Chad (I think), was saying he had run stock FMS rollers in some built motors with no issues
Old Mar 7, 2009 | 08:06 AM
T/S #25's Avatar
Need To Get Quicker
Years ago, when I still had a hydraulic roller, I ran more pressure than that. I used a set of FMS lifters and a set of Comp Cams springs with 200lbs on the seat and 440lbs @ .500 lift. Spun the engine to 7500rpm without any problems. I did, however, run all lightweight valvetrain components, oil restrictive pushrods and had killer oil pressure.
I think you will be OK with what you have.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Mar 7, 2009 | 03:53 PM
red vert's Avatar
original owner of the heads was just a lil off, measured them out today, they def have the k-motion pink stripe, but they have measurements of 230ish on the seat. These fuckers are stiff, from the measurements i figured out, I think that they are actually the k-900-1
K-Motion K-900-1 - K-Motion Valve Springs - summitracing.com
if any one has a set of hyd roller springs the wanna trade lmk.
Old Mar 8, 2009 | 07:14 PM
T/S #25's Avatar
Need To Get Quicker
Let me know exactly what you are looking for(pressure, size, diameter, etc)and I will check tomorrow and see what I've got. I have plenty of used sets at the shop, I just need to know what you want.
Joe
FordSpeed Racing
9.78 @ 136.05
Old Mar 9, 2009 | 01:52 AM
red vert's Avatar
PM'd
