Front end shake on a SN-95....Need ideas.
Old Feb 13, 2009 | 06:25 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
beat me to the inner tierod already. try checking those out
SUCH IS THE RULE OF HONOUR.
Old Feb 13, 2009 | 06:41 AM
shinysideup's Avatar
TR Balla Donor Supreme
I thought you said you checked for tie rod play?
Old Feb 13, 2009 | 07:37 AM
95coBraSVT's Avatar
banana republic
I checked the outters...I didn't know they even HAD inners. LOL I didn't see a ball joint for the inners like I do on my 67 mustang....So I didn't know they existed.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Feb 13, 2009 | 02:32 PM
DrDirt's Avatar
Team Geritol Racing
Drive only on paved roads without potholes when you're going to go over 45.
YO! Barry! You LOST!
Old Feb 13, 2009 | 02:44 PM
95coBraSVT's Avatar
banana republic
Ok, so now it gets REALLY weird......before I only messed around with the FRONT two rims and tires....Today I decided that since the car was freshly painted, it DESERVED to have the new rims ALL THE WAY AROUND....So, I took off the stockers and put on the new ones....I figured that if the rims were messed up, might as well make em ALL messed up. LOL
Well, I put them all on and then drove it. It was FINE! Dunno what was wrong with it STILL though.....I WISH I could have said I was high or something....But no.
Old Feb 13, 2009 | 03:36 PM
Tiffiny's Avatar
I can fix your bullshit
cool man
Old Feb 13, 2009 | 03:41 PM
  #17 (permalink)
DarkHorse's Avatar
Back again...
that sucks man i wish i knew so i can help....
((Get Staggered))
Old Feb 13, 2009 | 04:53 PM
  #18 (permalink)
GNs-r-slow's Avatar
Bondsman
Maybe it was coming from the back... those tire wear too
Old Feb 14, 2009 | 08:21 AM
  #19 (permalink)
kanji1jz's Avatar
jza70r
the tires could have had a separated belt with in the structure of the tire, or the belt could have shifted due to bad construction of the belts where they overlay inside the rubber. I have seen this happen countless times.
89 jza70r
3" exhaust w/ apexi muffler
xs engineering intercooler
sportmax 962 17x9 (r) and 17x7.5 (f)
kelly charger hpt tires
eibach lowering springs
kyb struts
sneed speed shop dual electric fans
max steel solid engine and trans mounts
walbro 255 fuel pump
custom 2.75" intercooler piping
R.F.L. bov (not a big fan but it gets the job done for now)
Old Feb 17, 2009 | 12:36 PM
  #20 (permalink)
SVT1996Cobra's Avatar
What?
Originally Posted by 95coBraSVT
I jacked up the front end, and the tires can move side to side, but not up and down. I looked at the lower ball joints, and they weren't shaking....I looked at the outer tie rod ends, and they weren't loose....Any other ideas? I'm stumped!
while your problem seems to have "gone away" for now.....^that is still not a good thing and a symptom of a bad inner tie rod. watch for uneven tire wear.
