broken axle question need help
Well you should be able to get the c clips off with that spring still installed. Remove the center pin and push the axle in....the clip should just fall off if not get a pair of needle nose and grab it. I have had many people bring me the diff to reinstall that s spring cause they removed it thinkin they needed to. Its a bitch to put back in.
But if you really want to get it out....get a pry bar and just pop it out.
^^^^ Push the axle in you should see it.
Best way to describe it....push the axles towards the center of the diff.....the on that broke you might have to get a long tube and a hammer to push that one it.
Like I said, you wouldn't like my way of doing it. I've changed the gears out before on an 8.8, but....I had help from a qualified mechanic....so I didn't really pay close attention since I decided I didn't like doing that because it stinks so bad.
yea push the axles in, half the time they fall out on their own. If they dont, just use a magnet extension and they will comeoff. You dont wanna fuck with that s spring!
thinking about it i havent even took the right wheel off with the drum maybe thats why the axle wount push in .......the broken left axle came right out with drum and rim and everything so i thought the right side would come out the same??? soo i have to unbolt the rim and take the drum out ..i am i correct now???
