SOS i need help!!
Old Oct 27, 2008 | 11:25 PM
  #21 (permalink)
GNs-r-slow's Avatar
Bondsman
If your distibutor is trashed go to LKQ and spend 10-15$ and get another one. Id also grab the module that bolts to the fender that goes with it.
Just a question, but does it happen to have a toggle switch for the ignition that you have to flip to start it? If I had to take a guess that switch got let on and burnt up the distibutor
Old Oct 27, 2008 | 11:27 PM
  #22 (permalink)
GNs-r-slow's Avatar
Bondsman
Originally Posted by Hurstmeister
Because at the level their playing at,.. usually 800 - 1500+hp motors,.. even HEI has its limitations. But for a motor that usually wont see more then 6000 its just fine. Typically if I was building a big block I would use an HEI.
They do make separate external coil kits for HEI distributors and they generally can handle the RPM's much better then the coil in cap setups.
Hurst
Not a trying to get in a pissin match with you but Pro-comp stuff is garbage, sorry
Old Oct 28, 2008 | 03:51 AM
  #23 (permalink)
Joker Instituted's Avatar
wanna be ford guy.
]there is no toggle switch but almost like it. the ignition was rigged befor i got the car. you turn the ignition to the on position and hit a puch button to start it. and im praying that the dizzy is it then. cuz it was left in the on position but i didnt think it would fry anything. at most i thought it would just drain the batterie.
its ok, the more parts that fall of the lighter i get.
Old Oct 28, 2008 | 05:19 AM
  #24 (permalink)
95coBraSVT's Avatar
banana republic
Yeah, Apollo Beach is too far for even ME to go right now. I wouldn't be able to do it till the weekend... Sorry man....We're trying to help you get it figured out.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Oct 28, 2008 | 05:24 AM
  #25 (permalink)
95coBraSVT's Avatar
banana republic
Originally Posted by 95coBraSVT
Ok, answer this question: When the dizzy was IN, did you crank it over and see if the rotor was turning?
If the rotor isn't turning, you have one of the following problems:
1) Timing chain broken
Or
2) dizzy gear messed up in some fasion
3) Cam gear is messed up somehow
Anything?
Old Oct 28, 2008 | 06:17 AM
  #26 (permalink)
GNs-r-slow's Avatar
Bondsman
If there was no fuse / link in line or no longer wired through factory fuse box there is no "saftey" can burn things up if left on for extended time
If you have a test light check the 12v sources to coil w/ key on
Have checked fuses to see if the one ING is still good and not blown? HTH
Old Oct 28, 2008 | 07:22 AM
  #27 (permalink)
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
if you have more engine parts in your oil pan then in your block .... it might be time for a new motor
Old Oct 28, 2008 | 07:28 AM
  #28 (permalink)
wanna be ford guy.
as soon as my slow ass friend get's here, we'll lift it up and check it out.
Old Oct 28, 2008 | 08:09 AM
  #29 (permalink)
wanna be ford guy.
how the hell do you get this little pick up out of the dizzy? i've been trying to replace it all day yesterday and today and the thing just wont come out.
Old Oct 28, 2008 | 09:36 AM
  #30 (permalink)
Mars_302's Avatar
Race Photographer
you need to pull the rotor , then you take a punch and knock out the roll pin on the actual gear at the bottom. then you have to knock or pull the gear off, slide the whole shaft out from the top and you should be able to get the PIP out then
